Vp44 transistor replacement
New to this great forum. Just wondering if anybody knows of anybody that has had long term success after replacing the transistor in their vp44 module??? I am referring to the “injector pump fuel valve” drive transistor that overheats melting its connection.
Anyone know what the original transistor was that Bosch used?
If so please let us know what transistor replacement you used?
Did you solder or use an adhesive to secure and provide the necessary heat transfer?
Thanks, Gary
http://www.digital-kaos.co.uk/forums/showthread.php/73680-Bosch-VP30-VP44-injection-pump-repair-solution/page7
https://www.westfloridacomponents.com/T143PE08/IRFZ44N+IRFZ44+N+49A+55V+Transistor+MosFET+International+Rectifer.html
49 amp 55v
If i ever had to replace a pump again ill keep the core and was contemplating doing the transistor replacement and using a non conductive thin oil being pumped through a cpu computer radiator with peltiers in order to ensure the electronics housed on the vp stay cool. as we all know the heat kills these and mosfet transistors generate a sh!t ton of heat which cant go anywhere else but the housing of the pump and which is cooled by the overflow of fuel through it.  thus why having psi over 14 to push the overflow valve open and getting flow through is mandatory.
this video lists this transistor. 55v 42amp
https://www.amazon.com/5PCS-IRLR2905TRPBF-MOSFET-N-CH-IRLR2905/dp/B01G0QHVQS/ref=as_li_ss_tl?ie=UTF8&qid=1509288828&sr=8-1&keywords=irlr2905&linkCode=sl1&tag=amp036-20&linkId=8cbb278a6229b5759f168da394f3c19d
this vid lists this transistor, 41amp 55v as well
https://www.digikey.com/product-detail/en/infineon-technologies/IRLU2905/IRLU2905-ND/305417
i am confident that i could do this repair easily. i have done micro soldering for years
what i am thinking is this is the driver that provides current to the plunger for the injector plate or something like that. makes sense that an electromagnet would need a lot of power to hold up against high psi injection system mechanism
Edited by CUMMINSDIESELPWR
11 hours ago, AlpineRAM said:
I seem to be late for the party :doh:
For  the 4cyl version in English
https://vrcustoms.wordpress.com/2015/05/18/vp-44-electronic-module-repair-opel-2-0-dti-x20dtly20dtl/
and here
that is a good write up of where the wires go and such, but man that soldering job is hideous!!!  lol
something like this requires a micro tip soldergun to be precise and clean.
soldering the transistor to the casing is good to use as a heatsync
it also looks like the vp44 housing can support a 4 port rotor head and the 6 port rotor head
i would also be willing to do this repair on a known bad pump for someone free and send back to see if it works (for the good of the cummins community).  any takers?
Figured better do a quick check on my “fuel metering solenoid”
before replacing the transister that drives it. Used the 2 intake heaters wired together in parallel
as a current sink in series with a headlight bulb ,15A fuse and the removed solenoid. The solenoid seems to operate fine with 12v applied. Still waiting for the transister. Thanks for all the input
guys.
