Quadzilla iQuad - no mph
SavageTusk
4 hours ago, SavageTusk said:
Just curious while I'm waiting for my PCM to get here, wonder why the radio is part of the CCD network?
If you do have Infinity factory radio and steering wheel volume control buttons then the buttons are connected to Highline or Premiumline Central Timer Module (CTM), the CTM relays the buttons commands to the radio via the CCD Bus.
So if the radio is not being used by the CCD network, couldn't these be terminated going to the radio harness so there's no chance that there is any bias from the aftermarket radio?
:shrug: ugh,  well I put the new, freshly programmed and tested PCM in and still no mph on the quadzilla.
So I get the speedometer reading on the Cluster but not on the iQuad.  I don't even think I can really say it's a truck problem, no check engine light, no codes..yet.  Do I need to trace the bus wires around some more?  I think I've exhausted everything besides replacing the ECM.  :thud:
Edited by SavageTusk
Try a simple test of resistance between ECM plug CCD BUS + - and ODBII data link connector (DLC) CCD BUS plug + -. -> (SEE PIC.)
Look for resistance with less than 20 ohms (Ω).
