01 cummins trans problems
ok guys any advice and idea new to the forum
I have a 2001 2500 5.9 trans started slipping I found a used one for a good price and purchased it only had 15,000 on rebuild
it was out of a 99 installed and had no o/d or lockup unless I used the l/u switch still no o/d replaced the governor pressure solenoid and sensor without any luck I'm getting ready to replace to o/d solenoid so I have to drop the valve body and ideas of advice is greatly appreciated this is all my first experience with transmissions
Any codes? If its the governor/solenoid you'll get a code. Also save yourself some headaches and just replace them both. I work at the dealer and whenever someone comes in I practically make them beg me to sell just one at a time because I got sick of customer coming back yelling at me for the sensor not fixing it so from now on I only sell both at the same time.
Assuming it is a good trans and all that.... How about your TV cable (throttle valve, kickdown etc.) or the connectors and wiring going to it?
Am i reading this right are you saying you have a lockup switch? Hows the jumper wire? Or is the relay still in there maybe? You guys didnt take apart the extension housing at all im assuming because thats the O/D housing as well.
Im just throwing suggestions out there and hoping to help
