Bad ECM or wrong vp44??
I recently put a HO pump on my SO motor and it idles at about 1100 rpm once it warms up. If you floor it it’ll idle normal. But the ECM has a few high voltage codes for sensors so I’m wondering if the 5v supply is going whack or if I need to get an SO pump to put on.
I would first make sure everything with your 5-volt supply good before I touch VP. Could be anything from a loose wire to a bad sensor, and could be any of them that share 5 volt Loop.
ECM is in control of idle, if you rev it up and it becomes normal, almost points to alternator putting out excessive AC current.
3 hours ago, Dieselfuture said:
I'm not an electric chicken,
But if you were and you leaned up against an electric fence, you might understand how back feeding could occur.
- John
Edited by Tractorman
forgot the word "fence"
28 minutes ago, Tractorman said:
But if you were and you leaned up against an electric, you might understand how back feeding could occur.
- John
I'm kinda beginning to understand but not sure how it works a 100%
If there is one charge wire going from alternator to pdc or battery, how can anything backfeed of it if nothing else is touching it.
Can someone school me on this
