No Bus question
I have been getting an intermittent no bus message since July or so. It had went away until my hunting trip last week. When it happens I of course lose all my gauges, but I can pick them up on my ScanGage2 through the OBD port. It seemed to happen on rough road so out of curiousity I tapped, or more like punched :mad: the cluster and everything came back up. This happened a few times. Since I can read speed, tach, etc. through the OBD port when the dash goes blank is it safe to assume that the problem is a loose cluster? Just trying to narrow it down before I start the long drawn out testing process.
Yeah I'm going to bet loose cluster. I'm pretty sure there was a TSB for cluster related no bus issue too.
Any idea what the fix was? I'm gonna make sure the screws are tight but if it's a bad connection I don't know what to do.
Guest 04Mach1
A few years back I was getting the "no bus" issue on my 01. I had found a lot of bus issues were related to loose cluster in Chrysler vehicles so out of curiosity I pulled the cluster to inspect and found nothing out of the ordinary. I reinstalled the cluster and haven't had any bus issues since. All I can figure was a loose electrical connection to the cluster before removing it.
