Guest 04Mach1
5w-40 will give better flow characteristics when cold. You could see a minor increase in fuel mileage too since the oil pump will use less energy to pump the 5w-40. I've been running Rotella 5w-40 in my 01 year round for atleast the past 6 years with zero negative effects.
Looking at the Amsoil spec's there isn't a lot of difference between the 15w-40 and the 5w-40, but the 0w-40 has an additional 14°F protection.
The hot properties of the 0w-40 are also better than the 5w-40.
I would personally get the 0w-40 over the 5w-40.
I can see that during the warm-up period but after that point the viscosity is the same between 0w-40 (15.7) and 15w-40 (15.6) so there is no gains to be had after warm up.
Just a point of reference for folks.
40°C is equal to 104°F
100°C is equal to 212°F
  • Like 3
2 hours ago, AH64ID said:
Sure didn’t wait too long for answers.
If you ordered online you can probably call them when they open in the morning if you want to change.
I buy in person at a distributor near me for cost
What I put in cost me 23 a gal retail is 30 a gal so ya makes it worth it to but it at that price
Technically if anyone is interested in getting amsoil cheap and wants to order I could have it shipped
Edited by Silverdodge
More like say u buy it from x company for 12 bucks a qt I can get it for 8
I’m a dealer and do it the same with a direct jobber down the street.
I’m going with DME this change, and I’ll be picking it up tomorrow.
But honestly the 5w-40 doesn’t have the specs to warrant going away from the 15w-40, when you consider all of them. The 0w-40 does, if you need the cold protection. Keep that in mind for next change.
I also didn't go signature I used ado usually i used adp
Gotcha, no 0w-40 available outside of signature series.
I didn't even think to look at ADO or ADP as I normally only look at their oils with extended drain intervals for non-DPF engines.
My dad runs ADP in his '17, since has has to change it every 6 months (or mileage which isn't often) for his forever warranty.
