Dead pedal/Alternator test
I will do that for good measure I appreciate the quick response and input. I’m chasing an intermittent dead pedal. I have a fass lift pump and a reman vp that was supposed to be less than a year old when I bought truck a year ago. I have done every test I can think of and everything passes. But with how sporadic the issue is I would expect everything to pass. I’m leaning towards an apps at this point but not throwing any codes. I’m not a throw parts at things kind of guy.
Interesting. We talking voltage drop from a broken/corroded wire between ecm and apps? Or bad ecm?
I would think a bad reference wire would throw a code. I could see how a dead spot in the potentiometer in the apps could cause the pedal to go dead without throwing a code
Edited by 69superbee440
Get you wireing cleaned up first with the WT mod and just all grounds in general, then you'll need some sort of life tool to see what apps does when you're driving down the road and it acts up. The 5v loop is just that, it's not 12v dropping that low, it is an actual 5 volt circuit that some sensors run on and when it malfunctions from a bad connection it causes random problems.
I was speaking of the 5v reference loop for the sensors that @Dieselfuture speaks of . I cut mine many years ago on the advise of someone I thought was smarter than me. That splice worked it way loose and caused several gremlins to raise their head. Dead pedal was part of it. By dead pedal I dont mean a dead spot thru the range of the accelerator pedal but rather the engine going to idle while under load with no response no matter how much you push the pedal. I did get APPS sensor codes during these issues but changing the APPS never fixed them.
 A dead spot in the pedal that you can push pedal more and get thru the dead spot is definitely an APPS issue.
Master ground for the big 3 computers (PCM, ECM, and VP44) is the passenger side battery cable.
As for W-T that would drop the AC noise for sure. As for the APPS sensor just monitor the value for sudden drops when it acts up or sudden 100%. Either way it will trip a P0121, P0122 or P0123 codes.
The only other device that will dead pedal is the VP44. Again this needs the W-T ground mod for protection.
