I am going to order a Quadzilla and would like some input from y’all. Options I see are 4K Adrenaline with Iquadbt for apple or adroid a non 4K model and a non 4K with control pod. What’s the difference between 4K and non 4K ? Android vs apple in reference to your phone preference or desktop? Advantages one way or the other? Anything else I should order when I place the order? Thanks a ton
4K is more so for extreme racing. Not for the normal person.
Non-4k is more of your daily driver and can tune to at least 3,700 RPM
Android with Bluetooth... Apple products can't send data over Bluetooth so WiFi has to be used. As for me I typically run headless. No display. I set everything up and run it. No need for display if you got a-pillar gauges.
Nothing is done of a PC other than flash updates. The rest of it is all done an on a mobile device. Tablet or cellphone. Like myself, I use my cell phone so when I'm in the city I can lock down the truck to 15% fuel so if someone wanted to steal the truck it only go 15 MPH
4K is only for trucks that are not used in a DD / Towing application AKA a race truck that needs more than 3700 rpm.    %95 of the vp44 trucks out there dont make power above 3500 rpm anyways.
bluetooth for andriod, which i Prefer as the datalogging is better on the Andriod system.
Thanks for the info I appreciate it!! One more question I noticed it has a high idle on it, will your high idle that I already installed interfere with it? Is the high idle on the quadzilla selectable meaning when I want it to high idle can I simply turn it on regardless of temps? Thanks a ton I really appreciate it
Thanks I appreciate it ?
