1 minute ago, Dieselfuture said:
Maybe I'll try to warranty one of these new Timken hubs. So much for buying made in usa stuff
I would most likely spend money on a Timken sorry... Just like I would most likely not spend money on Cummins parts either. Like everything I use has either been NAPA or RockAuto supplied parts.
I'm a slow learner, just wanted to support made in USA stuff
My wheel hubs are Timken I hope they work!
23 minutes ago, Dieselfuture said:
Maybe try bleeding your brakes again. Since you had the system opened up maybe there is still some are left in it that somehow is messing with a BS computer
I’ll do that. Also I read something about dirt getting in the sensor holes and such? Wouldn’t be surprised if some landed in they’re.
I’m beginning to wonder if ABS stands for Antagonizing Bull Sh$t instead of Antilock Braking System lol
Just now, Mopar1973Man said:
Check the ABS speeds while driving then see if a sensors is dropping during braking. Like my case the right time ring would drop to 0 after slowing 30 MPH. Mine was not the sensor but the unit bearing is bad.
Ok il do that as well. Do you think debris on or in the sensor would cuase this? I sort of remember seeing dust in theyre but didnt think much about it.
Maybe. If there is metal stuck to magnet of the sensor it can foul the magnetic field to the tone ring. As a metal tooth passes it creates an AC pulse. But with grease loaded graphite in the tone ring can do the same problem.
Ok plan of attack for this problem is to bleed brakes, remove and inspect front abs sensors, monitor ABS data...
