18 hours ago, Me78569 said:
If the computer doesn't beep at you when you plug in the quad then you don't have a data transfer cable.
It should beep regardless of everything else.
This is true too. I've got two cables that are only charging cable with no data pin connection. So those two cables do not beep at the time of plugging in. I do have one shot cable which is for my Garmin that also works for my Quadzilla.
Do you have anything else that you can plug in with those cables to see if your computer responds, like a Logitech remote or a GPS system (thats the only 2 things I can think of with the same plugs...).  If your computer responds to something else being plugged in with those cables but the XTZ don't then most likely the connection in the box is bad.
