New Injectors?
Are you talking about the boost fooler (72$) or one of the tuners like the adrenaline. Sorry for all the questions, been running the old dodge since 99 but it’s always been in stock form, new to all this go faster stuff.
Thanks
Bill
With a boost fooler and boost elbow on my stock truck with worn out injectors I was able to get around 30psi out of my turbo.  I think a boost fooler and boost elbow will be a cheap way to get a little more boost out of your turbo till you can get the money for an Adrenaline.  I would think that would help to clean up the smoke a little.
Covered... Boost fooler and tuner...
https://www.dieselautopower.com/quadzilla-power-1998-5-2000-dodge-5-9l-cummins-adrenaline-with-iquadbt
Boost fooler alone will do no good.
The ECM stock timing is too retarded for most usage. As you add more fuel more timing is needed. As you add more fuel you need to map the fuel out so to keep the smoke in check. When everything is right under the hood with fuel and timing that truck should tear the tires off.
Boost fooler made my boost jump from 21-22 to 35+ and reduced egts a very noticable amount. Truck whistles alot more to
I also have waste gait turnbuckled si it cant open so far I see no negatives to mechanically locking it shut.
