Boost gauge tubing
Ok guys i need to change out the clear cheap hose that came with the boost gauge for something more reliable. any suggestion? What is this polyon?
  • Replies 4
  • Views 2.9k
ive never had a real provlem with the clear line for a boost gauge although ive had it leak at the fittings on oil pressure, the only real alternative i know of is braided steel line 1/8in. but youll have to swap out all the fittings on the manifold and gauge with a/n fittings like earls or aeroquip and this is not cheap!!! maybe somebody else has a more economical solution
Get a chunk of 1/8 Air Line (Polyon) from NAPA for cheap... It rated to 200 PSI typically extremely flexible... I bought 10 feet and 2 ferules for $6 bucks... [ATTACH=CONFIG]1548[/ATTACH]
Thats the same stuff I am running for boost. I need to get my DP switched over one of these days.
