Uneducated second gen owner in need of help
41 minutes ago, 98whitelightnin said:
Are those pumps adjustable? Looks like you can turn up the pressure with and allen wrench. That drips is diesel but idk if those are push lock type fittings that can be cut off.
I’m not sure, I’ll lyk as soon as I can though.
I can turn up the pressure by using an Allen wrench?
1 hour ago, Kane4sythe said:
I don’t have two filters
You have raptor. Did not know those came in 4g.:doh: My AD 165 has a dual filter head.
If its just a drip it wont effect your pressure enogh to notice. You might put a small stainless steel hose clamp on it and see ifmthat helps it. I cant remeber whether those quick disconnects are are push lock or barbed or fixed like @98whitelightnin is saying.
Can you get a picture of the fuel lines a few inches away from the pump on either side?
Since you do not know your what uour  pressure is, I would not turn it up. You do have enough pressure to make the fittings leak. So there is pressure there.
Edited by dripley
I will not be home to see my truck til Tuesday so I will send whatever pics are needed then.
So if my gauge is reading 0 psi, would you say that my gauge has most likely just stopped working? I have three gauges all mounted in the same bracket, the other two have good numbers so idk what’s going on with my pressure. I’m hoping just a loose wire or something along those lines
Maybe the gauge or a wire as mentioned. A lot of that depends on whether you have a mechanical or electric gauge. Hard to say. A test gaige, some auto parts store loan them, would be you best bet for now and there is a test port on the VP.
Edited by dripley
Can you hear the pump when you turn the key on but dont start the truck.  Itl run for a few seconds then shut off.
On closer look those might not be half inch lines
Those are 1/2" line.  I have the same pump but not 4g. There should be a plus or minus showing wich way to turn Allen bolt to raise or lower pressure.  I'll go look at mine and tell you. I dont see the plus or minus.
I think these pumps are set to be about 16psi . I turned mine up to 20.
Mines leaking yours looks pretty clean and new.  I'll have to look into the 4g pumps. It might be getting close to time to freshen mine up.
No one said I could post pictures. If I subscribed
To me 33x12.5s look pretty good.
Edited by Evan
Storage amount is listed on the subscription profile for each. Like Silver...
Quote
100 MB of file storage
Yeah there typically set for 17 PSI from the start. 3G pumps have a bearing and seal issue. the 4G pump is upgraded to double seals and better shaft bearing.
