Just dreading what I have in my future. I don't remember having all this mess of wire everywhere in my previous truck. Ugh... Battery terminals have screws jammed in them on the passenger side to keep everything snug. :doh:
Driver side positive post must have 5 additional lugs hooked to it. 0629192041.jpg.d28c94436683a99def00387e8b3274a4.jpg
Nothing is every attach to my batteries. All hooked up in the PDC box where it should be. My batteries are clean. Too bad your in Texas I would be more than happy to fix that mess and make it go away.
I'm almost considering saving up a chunk of money and taking it somewhere very reputable with electrical.
The mechanical side of things I'm comfortable with, electrical I'm not. I ordered new battery terminals last night, I plan on doing WT's mod. Then I may try n figure out what all this mess is. Or I may let someone knowledgeable do it for me... I
:shrug:
take it one wire at a time,  Pick a wire, follow it, see what it powers.  If you don't need or use it remove it.  If needed rout the wire next to existing wire harness and cover them with a split wire loom for a clean install and terminate them in the PDC or add an auxiliary fuse box.like the one shown below.
  • Like 4
