So this morning I started the truck and drove to class and everything was normal. Get out of class 2hrs later and go to start the truck and as soon as I do I know something isn’t right. Truck had a miss and. Is smoking white haze pretty bad. Whole engine is shaking and engine is missing sounds like. No knocking or anything like that. Injectors are only a year old. What would cause it to just go bad while sitting for a couple hours? Had the truck towed to my apt and am going to swap in my stock injectors once I get time (currently pouring cold rain) and hopefully that fixes the issue
  • Replies 9
  • Views 5.1k
You could fire it up and crack injectors itl run rougher each time you crack a line.
You may find one that doesn't make it run rough when you crack the line. That way you can pinpoint wich injector it is. If it's an injector ? Take it to shop that does injector work and have it checked out.
This is the same as pulling a spark plug cable off the plug to figure out wich cylinder is missing on a gas motor. The one already missing wont cause any miss when you pull the plug cable off the spark plug.
  On 10/22/2019 at 3:32 AM, Royal Squire said:
Fuel pressure?
Have fuel pressure and oil pressure.
  On 10/22/2019 at 1:02 PM, Mopar1973Man said:
Could of been a nozzle that cracked. Pintle needle stuck open.
In any case send them off to be pop tested is the right thing to do.
That’s what I’m hoping. This injectors are only maybe a year old. Going to try and figure out which cylinder is dead and take that injector out and clean it first to see if that does anything.
Yup I plan on doing this once it stops raining.
Pulled valve cover this morning. #1 cylinder rocker arm but appears to have backed off and and wasn’t doing anything consequently. Going to find someone with a feeler gauge and do valve lash and should be good to go! I’m just happy it’s on #1 so it won’t be too bad but I’ll more than likely go through and do them all since I’m in here.
I would definitely do them all. There is a good article here on a simple way to do it.
You need your girlfriends makeup mirror
Maybe we all need a good sense of touch, the girl friend or truck.
I used a mirror to see tdc mark
