- Replies 4
- Views 1.7k
								Me78569 2 posts
								Evan 1 post
								backcountrymountains 1 post
Back again.
I towed the tiny house from Tucson to Denver last summer and it was a little slow. Besides being heavy, the house is just as aerodynamic as a 13' x 8.5' flat wall. I couldn't shift into 5th on the nv4500 unless I was going downhill. I couldn't keep up with the semi's at 65 mph unless I was running 4th at 2400 rpm so I just cruised at 55. The rollers between Trinidad and Pueblo had me in 3rd at 40 mph. There are a lot of rollers.
All I want to do is use 5th gear to keep up with the semi's and maybe go over a rolling hill in 4th.
Anyway, 'tis the season of sales on upgrades so I got a Quad v2. I'm sure the quad will help add fuel and get some power but when does my stock HX35w run out of air to burn and keep the EGTs reasonable? Can the HX35 support 7 x 10s and keep the EGTs down for towing? If I upgrade the injectors can I run a milder tune that will keep me from smoking my clutch and melting pistons while towing?
Local diesel guy recommended against bigger injectors unless I upgrade the turbo because the EGTs will be too high. How the heck do I even choose a turbo? There's a million options. I'm not looking to spend $5k for compounds just yet.
Throwing in a @Me78569 call-out for advice. How did the he351ve hold up? Vanes still move? I was thinking a he351cw might be an economical upgrade for me.
Thanks for the help,
Justin
