I flushed my coolant and let it run till clear, then let it drain. When i add coolant it so far only took 4.5 gal. I drove it around and checked when I got home and only added a quart. Did I do something wrong or do I have an air pocket...thanks
Most likely didn't drain out the block very well it can hold a extra 1.5 to 2 gallons of water if just sitting flat ground. When I drain mine out I either jack up the rear of the truck or back it up a steep bank.
Exactly as Mike said, the block holds a lot of coolant, over 2 gallons on mine. Because of this I would do 3-4 flushes before adding coolant. Add the concentrate first, and use enough for the half the full volume, then top it off with distilled water and you will be at 50:50.
Thanks for the input, and I believe you are right, so back to wal mart for some more Preston and will do it again.
If your in florida or some southern state I would most likely let it slide and just top off with straight coolant... But Idaho I know gets cold so yea its a good idea to re-do it... :rolleyes:
