Safe to assume my alternator just quit?
I tapped into an unused fuse pin. Worked great for me. It's been that way for years. And the fuel heater is run from the ECM is run right through the fuel heater plug.
I have a master switch, that controls it but yes I have it too.
Mine is just hooked to the PDC where the red lead from the battery comes from the driver side battery to the PDC. Right on that stud is totally safe for the AirDog and the terminals will not rot.
15 hours ago, dripley said:
I landed it on the terminal the alternator used to be on.
That is also a good spot if you have done the W-T ground wire mod. If not do not use this side again if the fuse blows it will wipe out the fuel pump motor.
