- Replies 30
- Views 7.7k
jtrakel 13 posts
dripley 7 posts
IBMobile 4 posts
Royal Squire 2 posts
Popular Days
We did have a couple kits get sent from FASS with the wrong harness with the kit. Can you confirm the part # on the bag? send pics to warranty@dieselautopower.com and Mitch can give more help on Mon
If you have the relay wired with the ECM triggering it then you can get the fuel pump to run without bumping the ignition/starter. You can remove the relay and put a jumper wire between terminals 30
Yes, I've done it to bleed the system when MoparMan and I replaced the injection pump, when I've replaced fuel filters, and when replacing injectors.
Good morning, currently installing my FASS 165 LP and the directions have me installing an Add-A-Fuse into a ignition hot fuse under the hood it does not talk about wiring the LP into the PCM at all. Can someone point me in the right direction as to where I should place this "add-a-fuse" for the ignition hot. I've added the install manual i'm working with for reference, it's on PDF page 13 step E and F.
Thanks and cheers!
TS-D08-095G-or-TS-D08-165G-2.pdf
