Well guys, it’s time to change the clutch in my 02 with 103k on it. It held all last summer until I got it to slip up hill in 6th with the quad on level 6. This truck is a summer driver/toy that I plan on building to around 500-550 hp. My brother has an 01 with this clutch https://www.dieselautopower.com/1999-2005-cummins-nv5600-13-x-1-375-single-disc-performance-replacement-ceramic that I’m also considering. However, i’ve read that a factory replacement pilot bushing may be a better option than the bearing. I’d hate to have the bearing fail and pull the trans again. Thoughts on this? Also as far as the flywheel goes, would my best option be to just get it resurfaced? First time doing this job so all advice is appreciated.
  • Replies 11
  • Views 3k
  • Tractorman
    Tractorman
    You will probably hear different opinions about pilot bearings / bushings.  My original clutch replacement was at 297,000 miles due to a OEM pilot bearing failure (needle bearing style).  It caused so
  • Great work!
    Great work!
    Bushing or bearing both have pros and cons. Bearing better performance less fault tolerant. Bushing better fault tolerance less performance. The 6 speed is already stiff to shift and hard on syncros s
You will probably hear different opinions about pilot bearings / bushings.  My original clutch replacement was at 297,000 miles due to a OEM pilot bearing failure (needle bearing style).  It caused some damage to the transmission input shaft pilot bearing surface.
When you buy clutch packages, new flywheels are cheap compared to trying to resurface and cleanup heat cracks and hot spots on the old flywheel.  In my opinion resurfacing the old flywheel is not worth the risk of poor performance (grabby, chattering, slipping clutch) that could occur, especially when considering how much labor is involved to replaced it.
- John
Bushing or bearing both have pros and cons. Bearing better performance less fault tolerant. Bushing better fault tolerance less performance. The 6 speed is already stiff to shift and hard on syncros so a bearing could be better.
I believe there is an oversized roller bearing that's offerd or so I heard, it ether come with new flywheel or you need to machine original bigger to get it to fit.
I'm running the Valair Dual Clutch... Let say I won't buy this one twice. I'll return back to South Bend Clutch with a dual disc in their set up. Hold the clutch in the throwout bearing is loud. I've had my transmission out twice and inspect the clutch twice and there is nothing wrong with it. Just a loud clutch. My pilot bearing is sealed ball bearing not needle rollers like stock.
Ok so the needle bearing came from the factory, I thought I read it was a bushing. Did your sealed ball bearing come in the kit? It’s kind of hard to tell but it looks like a needle bearing in the pics on dap’s site.
Yes, already pressed in the flywheel. Both South Bend Clutch and Valair have sealed ball bearings for pilots in their flywheels. All you got to do is order a full kit with flywheel.
The new flywheel I installed with the Southbend kit came with new bolts.
So I’m thinking I’ll be better off with a kit rather than piece it together. Considering this https://www.dieselautopower.com/south-bend-clutch-multi-friction-dual-disc-clutch-kit-750hp-1400ft-lb-with-flywheel-sdd3250-6. I was thinking about going with the single disk valair because I’ve heard about slower shifting and noise vs the dd. However, it is very heavy and aggressive for daily driving in my brother’s truck. How do the new south bend dd’s compare?
Shifting... Not a huge difference but just a touch slower on carbon syncros, now on brass syncros seem pretty good for shift speed. Throwout bearing noise is loud on the Valair, lauching on mine for what ever reason the clutch is jerky and grabby. As for performance I've never been capable of spinning that clutch even with the power I create and can roast the rear tires. I would do a second dual disc again but I would go back to South Bend Clutches.
Thanks guys, I think I’ll go with that south bend dd. I’m also going to buy injectors at the same time. I’ll update this thread when I do the clutch, most likely within the next few weeks.
