Ok folks I need to know if I take the banjo fitting ( return line ) off at the vp and blow air thru it to make sure it's not stopped up , will it hurt anything like crossover tube orings. I just wont to make sure the return to the tank is open. Also will it hurt vp?
No starting problem, surging problem and slite miss. The only thing that has not been replaced is mapp and ait sensor, water temp sensor. I was thinking if return is slite stopped up it my cause it. Just trying anything.
Do you have the fittings to run the return into a container to test it out, that would take the plugged line out of the equation. just a thought.
I can not understand how clean, filtered fuel could possible plug up the return, after it went through the small tolerances of our VP44? :smart:
it was probably clean through the 44, then a small compression leak at the injector will soot the hell out of it on its way back to the tank.
