- Replies 21
- Views 8.8k
beautifulisblue 9 posts
Rotax3006 6 posts
CUMMINSDIESELPWR 3 posts
Tractorman 1 post
Yep starting well, can't replicate the problem. Need to get it nice and hot tonight and double check.
Soon after I bought my used '01 in '03 with 34k miles on it, I had a hard hot start. I was towing a pickup on a real hot day and let my fuel tank drop down till the low light came on, I wanted to fuel
The good news is that those are not the VP death codes, of course that doesn't mean much. It does not sound like a fuel leak to me. It would have to be a major leak for a hard start immediately afte
Hey folks,
I've got a hard start issue that started when I pulled off the interstate in 115 degree heat. Almost always has a hard start if the engine is warmed up and sits a couple minutes now. Sometimes it will hard start if sitting overnight. The first time was 1k miles after a fuel filter change on a road trip from Vegas to southern Idaho, but I did the standard bump the pump and it ran great after that. I can't see any fuel leaking anywhere. I've always seen a little drip off the tank if I really top it off, but that's been the case since I bought it.
I just ordered a DDRP from FASS, but haven't installed it. I'm driving a loop from Vegas>Oregon>Idaho.Vegas in a month with a small horse trailer and a couple pack llamas in it. What's a good way to test the fuel system before hand? Once I had a pump I could run off a battery and traced an air leak to a cracked pickup in the tank with a clear hose that way, but alas no more pump.
I know this truck has at least one stock style lift pumps and a upgraded VP44. it normally runs 13psi at idle and 9 PSI cruising, can go down to 7 WOT, hence the DDRP.
Any chance I could be having an o-ring problem with the fuel filter that took a thousand miles to show up? I snugged it down with a one and a quarter inch socket.
Thanks folks,
Edited by beautifulisblue
