Dash wiring harness compatibility
- Replies 18
- Views 8.2k
Jnull 9 posts
dripley 3 posts
Dieselfuture 3 posts
Great work! 2 posts
I don't think too many here know much about ppump conversions. @TFaoro was one of few that did, but hasn't been here in a while. There are few other guys that knew more that I haven't seen in sometime
ECM and PCM are both fried. Start with sending them both out for repair. Then pull the entire harness out and send it to Auto Computer Specialist and they do full wiring harness repairs. The external
It's what @Mopar1973Man said, a fuse on a charge wire from alternator to pcm. There is an article here somewhere. In case alternator shorts out it will blow the fuse instead of pcm. WT is a very good
Hi guys new here, mopar man I miss seeing you on CF!
Im hoping to get a question answered that isn’t getting much traction on CF. I have a 98.5 24v a friend begged me to take off his hands as it’s pretty modified and a lot of poor work done to it. It’s ppumped, has an external voltage regulator wired up and every light on the truck inside and out quickly pulses, WTS light doesn’t come on, gauge cluster works intermittently, fass is wired to an always hot toggle switch, etc...
Im swapping out the entire dash for one pulled out of a 99 1500 and I’m hoping to use the 99+ headlight/fog light switch and move the airbag selector up to the 99+ spot.
Would a 99 diesel dash wiring harness be a plug and play direct swap into my 98.5? I believe the only change is the headlight switch, from looking at the 98.5 and 99 Airbag selectors they appear to have the same plugs on the back and the only difference appears to be the shape of the housing since they mount in different locations. Any help would be appreciated.
