2007.5 Dodge 2500 6.7 fog light conversion
- Replies 7
- Views 3.3k
Mopar1973Man 3 posts
Rogan 2 posts
01_Cummins_4x4 1 post
Dieselfuture 1 post
TIPM (Totally Integrated Power Module) this is what actually turns on the fog light. Double check the fuses. Beyond that the fog light are turned on by CANBus message not by a voltage switch we all kn
Unknown, but the entire headlights and fog light are controlled by the TIPM. There is zero relays in this system. Then the only fuses are the ones you see. Nothing more. This is not like
Yeah, I went through this same issue with my 07.5 (factory no-fogs). I added, and had to turn the signal on twice (on, save, off, save, on, save) before they started working.
My neighbor that lives across the road from my family's ranch on the mountain, has a 2007.5 Cummins 6.7 2500 4x4 pickup that I just installed a brand new Clutch, flywheel and hydraulics in it.
A while back he had a different 07.5 2500 Cummins that had fog lights from the factory. He swapped the front bumper assemblies, and swapped in the headlight switch with the fog light function.
He can't get the fog lights to come on. I just went into his BCM and turned the fog light functionality on, but when I press the headlight knob in to turn on the fog lights, they still don't come on. The fog lights worked when the setup was on the other 07.5 pickup.
I looked in the fuse box (TIPM) but I don't see any fuses labeled for the fog lights, so I assume they run off a relay?
Does anyone know if there's a fog light relay or fuse in the TIPM and which spot it's in?
