- Replies 8
- Views 3.1k
Mopar1973Man 4 posts
dieselautopower 2 posts
dripley 1 post
LorenS 1 post
I think there is some lag with a boost gauges (mechanical has line to pressurize, electrical has processing) Instead of relying on the MAP sensor and Dodge ECM....use the Quadzilla. Hook y
This is why I don't rely directly on the Quadzilla display for gauge knowing the limitation of the sensors and ECM. ISSPro EV2 Boost 0 to 60 PSI with my warning light set to 45 PSI. I can
Eric at Vulcan Performance built that for me. Now what it is basically a piece of scrap angle iron. Now find double female 1/8" NPT bushing. measure the OD of the coupler and drill just a bit smaller
What's everyone one using for a map sensor? My stock one maxes out at 40psi. I'm suspect that I'm making more boost than 40. I have the quadzilla BT gauges and dont want to run manual gauge.
