Injector issues?
What issues did you have with the DAP besides fuel knock?
Smoke and haze is normal with DDP.    I am not sure if that has gotten worse or not since DAP injectors.
Is there an actual driveablity issue beyond the noise and haze?
The smoke is much worse with the DDPs. The fuel knock is still there, but not all the time. There is no driveablity issues. Just smokes all the time regardless of throttle. It does not smoke at idle, only under throttle, EGTs are about 750 to 800 at 65mph.
Like myself I'm still a 7 x 0.010 DAP injector VCO popped at 320 and nearly zero smoke. Initial stomp of the throttle its will smoke some but clears quickly. I just had @Jthor driving my truck home as I followed with a customers vehicle. Still more than enough power to spin the tires loose on dry pavement.
1 hour ago, Me78569 said:
I would talk to DAP.   they have good budget stuff.
Why did you change from DAP to DDP?
They were used from a buddy and thought they were the causing the issues I was having, but I was wrong. They were definitely better on smoke than the DDPs, so I'm just going to swap the nozzles and re pop the DDPs and call it good
2 hours ago, Me78569 said:
I'd send your DAP's back to DAP and ask them to go over them for you.  It will be cheap and they can fix any issues.  Then throw them back in and sell your DDP's and get back what you can.
@dieselautopower
I dont have the DAPs anymore or I would, I gave them back and my buddy sold them. So I might just buy some DAP vco nozzles and put them on the DDPs and re pop and be done with it so my truck is not down while I send them to DDP
