My no bus adventures/question
- Replies 8
- Views 2.5k
Mopar1973Man 3 posts
panzerq 2 posts
IBMobile 1 post
JAG1 1 post
Hi, long time lurker first time posting. Gotta say have read alot on this site has some good Info.
Had a issue the other day with my 2000 24v auto. Drove it around all day fine, parked it in the drive way and changed my brake light switch since the brake lights stopped working. After that they still didn't work so I swapped my multi switch with another one, still nothing.
Went to fire it up and got a no bus message on the dash, will crank but no start, fuel pump won't prime gauges dont work for volts or fuel level when not running. After messing around checking all the grounds which are tight and clean. Truck has 76k miles on it. Did some more testing, have 5 volts coming from orange wire down at the trans plug.
Found if I put a jumper wire in the asd relay, it will start and run fine no codes. Charging was seeming a little funny after running idling for awhile, cooler here so grid heaters ran for awhile. Was charging at 15 volts and he needle was dancing a little in the cab.
Planning on doing the ground mods, and see if that helps.
Any other thoughts?
Thanks
