- Replies 68
- Views 9.5k
JoeMcCaz 29 posts
Mopar1973Man 13 posts
Turbo Terry 6 posts
dripley 5 posts
Installed M5s popped @ 280BAR yesterday, no more stalling finally "had" my truck back. Yes "HAD". Took for a run with Edge on 1-3, ran great, let egts cool down, comp on 5-5, ran great. Yee has! Late
All that foil wrapping and such you mention is not needed as long as the electrical system is working properly. It will hide the real problem which is most likely to much AC voltage from the alternato
Hey Terry, you are a fortunate man to have grandchildren that, 1- wear you out and more importantly 2- help keep you young. My only child, daughter turned 30 earlier this month, told me when she marri
New annual member here. I'm hoping someone on this site can help figure out what's causing the stall issue.
Without writing a novel, as I have on other forums, I'll be as brief as possible and try to provide as much info to help repliers and to ward off 50million posts that will just skew and clog this thread. In advance, no offense intended and I welcome all well thought thru replies, Thanks.
I acquired my truck (wish I could figure out how to create a signature?) in May of 2001 it had 75k on it and bone stock.
July 2001 installed gauges: combo boost/egt, fuel psi and trans temp.
Spring 2003 with 130k trans started slipping, had DTT master rebuild done. Outside of trans build, alignments and tire installations "no one" has wrenched on my truck but me.
Fall 2003 Formula1 (now FDI) Mach 1.6 (85hp) injectors, Edge Comp (VP tapped) and relocate LP to frame. At some point I got it on a chassis dyno and it rolled like 350hp & 790tq.
Fall 2006 Mach 5 (200hp), HTT QD 64/14 turbo, Vulcan Draw Straw, Walbro pusher pump, big line (1/2) kit and spin on filter at frame. Spring Fling 2007 rolled 525hp & 1000tq.
March 2009 original VP just died. New VP installed back on-line.
Fast forward to Fall 2020 and 260k miles, hazing at idle more than I cared for, sent injectors to F1 for a refresh figured they were pretty old and had in excess of 130k miles or so on them it was time to give the old gal a tune-up.
Immediately after receiving and installing the injectors the truck began stalling when placed in gear (Drive-D or Reverse-R) or if it didn't stall the idle (850) would violently/quickly drop to 500 and then jump back to 850.
There's more to the story since Fall 2020, but don't want to create a novel in my first post and don't want to skew fresh thoughts from you all with things done since then.
Have at it guys and gals. I so look forward to your replies.
