47RE TRANS SERVICE WHAT FILTER STYLE TO USE W ATS DEEP PAN
- Replies 7
- Views 6.1k
JAG1 2 posts
Dmaxgpe 2 posts
Mopar1973Man 1 post
Evan 1 post
I am going to install an ATS deep pan on my 47RE and if I remember correctly Chip's Trans in TN used the 727 style open Wix 58707. The ATS extension block for the deep pan has 2 holes vs 3. Does it even matter what filter design is used between the 2? I guess if I run the early version I just need to confirm the orientation is the same as before with the large hole. Thanks in advance for any input!
