Traction Bars for short box 2wd
- Replies 11
- Views 2.3k
Mopar1973Man 5 posts
Doubletrouble 2 posts
VMac822 2 posts
Tractorman 1 post
Popular Days
I'm running about 500 HP to the rear tires I do have a bit of axle wrap, but not bad. Running a 5 speed which I enjoy way better than the G56 that is in Thor that I really don't like at all. 4th gear
I run my fronts at 65psi all the time. Seems to turn and handle better as far as steering. Rears are at 40psi when empty, 50 when towing the camper. (10k fifth wheel). I was mainly referring the
Yes. That cost a few bucks to put together but it turned out great. Was hard giving up the lightweight aluminum one piece but I know it wasn't up for the extra torque. I didn't make any
I recently tossed the automatic and installed a G56 manual in my 98.5 short box. Love the trans but now I have too much axle wrap. My rear springs are on the soft side because I took a leaf out of each side to improve ride and offset it with a pair of coil springs.
I have had traction bars before, on this truck and two previous trucks. Each set sucked. The last set I paid something around $700 because they were supposed to be good and beefy, but the heim joints quickly wore and rattled and clunked like mad. . .heims at both ends (bad idea and not quality ones at that). Also it seemed to bind suspension travel, ride quality wasn't that good.
On another 2wd truck I installed a used set of Caltracs for a 2500 Ram, but after endless fiddling and adjusting the ride was not that great either. Generally the ride was okay except railroad tracks or large bumps caused the back end to have nasty rebound effect, made the back end of the truck to buck badly.
Looking for suggestions or options. The disadvantage of a 2wd is less leverage to combat axle wrap because of not having the spacer blocks. I have thought about a large single bar, mounted to the topside of the pumpkin or a special cover, but there isn't a good spot on a frame crossmember to mount the other end.
