- Replies 16
- Views 3.3k
AH64ID 3 posts
Silverwolf2691 3 posts
Andyba20 3 posts
Mopar1973Man 2 posts
Well... I'm starting as low as 60% on Zero boost and ramping to 100% by 5 PSI remain 100% till 15 PSI and ramp up to 150% at 30+ psi. Way better cold engine protection with it locked low like that EGT
Probably because the people that are common on the internet with the older trucks aren’t the type that tows heavy. It’s just been too long since these older trucks were king. No matter the m
I think so. I already do that with the original OEM turbo (HX35), RV275 hp injectors, and mild tune with a Smarty S03. My travel trailer is light - a little over 5,000 lbs (GCW is 12,500 lbs) and I
It seems like everybody thumbs their noses at small compounds these days, but everyone I’ve ever talked to that has had them loved them. I’m specifically referring to stock/s300 type setups, I’m pretty sure the old BD kits used an S300 as the primary. Any idea why we don’t see that setup offered much anymore? Is it just due to a shrinking market and the S400 working better for the 5.9/6.7 crowd as a whole? I’d think someone valuing quick spool and low egt’s more than big power would enjoy the smaller setup…any theories? I’m sure I’m oversimplifying it or missing something. Maybe they really are good set ups, there’s just not a big enough market for vendors to sell them.
