Fix it while in there?
All - planning a VP44 replacement soon and I'm wondering while in the vicinity if I should take care of a few other things. Namely tappet cover gasket, vacuum/steering pump seal, cam sensor.  Think this "while i'm there" question has been asked a million times. What say the folks here?
The one thing I wished I had known was the gasket for the intake air heater... I believe it takes two... and yes the tappet cover gasket can't be done without pulling the VP.. though when mine was done they had issues with just the gasket, ended up needing a full tappet cover and gasket.
2 hours ago, Hutch24v said:
cam sensor
Can be done without pulling the VP44... I've done several and super easy...
Again can be done without pulling the VP44... Just 4 nuts and 2 bolts and a oil line it can be removed and rebuilt.
Best to have the VP44 removed here so you can reach the front bolt and install the tappet cover without damaging the gasket and get everything lined up properly and sealed.
