    We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features.  Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
I'm pretty sure now it's a loss of prime. Somewhere in the crossover and injectors yet. I managed to get all set up a graphic display of rail pressure. The lift pump comes up fairly quickly to 14 PSI then the rail starts at 84 PSI engine off and key on. Now when lift pump hits 14 PSI quickly order the rail bounces from 84 PSI to about 1,1xx PSI continues to crank then the  surge hits at 12,xxx to 13,xxx PSI and the engine starts the pressure settles at 6,xxx to 8,xxx pulsing.
Changed the supply banjo seals on the CP3 and stopped a weeping leak. Then for fun pulled the fuel filter to look at filter condition and lid seal. Filter needs changing and the seal I changed from a salvaged seal. The crank time is greatly reduced but still could trip a grid heater light on only deceleration and its a 10 chime account again. The grid heater light can be reset.
9 minutes ago, Tractorman said:
Whadda ya doin'?
- John
:lmao::lmao2:
:whistle: Injector inspection. :wink:
I managed to get all 6 injectors removed. I'm going to town for a scotchbrite pad and brake cleaner.
Update...
So i pulled all 6 injectors doubled checked the fitting of all parts and made sure all parts were of good condition. Now brake cleaned all parts and mating surfaces to bet sure everything was clean and job is done absolutely right. Now during reassembly I had the terminal post snap off the #1 injector and I'm going to have to send this one out to be serviced and repaired. Sadly I got a delay to fix one injector and already called @dieselautopower and talked to Mitchell and got everything ready to ship out tomorrow.
Temporary pause button on Thor for the moment... :ahhh::rolleyes::duh:
So, at this point it doesn't sound like you are seeing anything that would be contributing to the symptoms you are having - is that correct?  Bummer about the broken injector.
- John
Still the logics of the ECM is calling for high return rate possible misaligned injector / crossover tube not seating. This is why the grid heater light and chime. Which also part of loss of prime issue possible all relayed but need to finish and try starting but now wait for mail back and forth.
On 12/31/2024 at 3:58 PM, Mopar1973Man said:
The lift pump at key on rose to 14 PSI during grid heat. Then, during cranking, the rail jumped to 17,xxx PSI and continued to be hard to start. Now, I stopped and unplugged the FCA and tried again. The lift pump again rose to 14 PSI during grid heat. Then cranking jumped to 17,xxx PSI, and I also continued to crank until it started. The only difference was the FCA disconnected rail stayed max pressure where after starting with FCA would drop back to about 7,xxx PSI roughly.
The above post indicates that fuel rail pressure rises quickly to well above 4,500 psi, but the engine continues to crank a long time before starting.
This post indicates that fuel rail pressure stays well below 4,500 psi during cranking and the engine won't start until the pressure suddenly jumps above 4,500 psi.
Which post is correct?
- John
Posted (edited)
Both really. It is random depending on how deep the rail drains out. I've left both the lift pump gauge hooked up and typically watch the live data tool. Again numbers vary based on how much the rail drains off.
Those are two different run cycles showing the changes from one start cycle to the next.
Since this article I've been fighting this..
Project Thor continues... Mark found me a set of bumpers, 8 foot bed, and tailgate and swapping the flat bed and winch bumper. I'll post up photos what we see when I get to Jordan Valley, OR.
Made the trip out to meet my guy on the bed trade I'm doing. I'm trading the super heavy winch bumper and the steel flatbed with toolboxes. Here is the bed I'll get.
Yeah it's rough but workable. Now to get my injector back in Thor so i can roll it out of the shop.
Once you have the bed do something around the hile for the gooseneck hitch. Mine rusted out all the way around that. I now have a hole 20" front to back and all the way from wheel well to wheel well. They cut it out for the hitch but didn't seal it or rust proof in any way.
 I now have a rubber bed mat screwed to the bed floor to cover it so I don't fall through. I have another bed for the truck, just haven't had the time or money to repaint it and swap them. (The spare bed is black, truck is silver)
 My "new" bed has a small square hole innit for a gooseneck as well. I'm going to cut a piece of bed floor out of the old one and section it into the new one. The new bed has been rhino lined so once the patch is in I will go to rhino liner and have it filled in and spray the patch area from the bottom also. That way it us sealed on both top and bottom.
I've got a sheet of metal here I can cut a full width chunk and tack weld the piece in place. Then straighten all the remaining edges and weld them down to the sheet metal. Now like get a gallon of Hurculiner and cover the host of sin on the bed bottom.
  • 3 weeks later...
So... I've got the one injector back from @dieselautopower seated and installed in the head again. This is nuts I'm losing prime instantly. I'm still fighting loss of prime issues which is nearly instantly. If the engine stalls or shut off it impossible to start again, super long cranking.
I'm still seeing about 2,xxx PSI swing in pressures at idle on the rail I'm getting both 5 chimes and 10 chimes grid heater light. If driven slowly under 40 MPH it will not set the grid heater light. Extremely hard to start hot. Once the grid heater light is on the rail pressure is forced to 19,xxx to 20,xxx PSI all the time your driving.
I've even changed fuel filters just for the sake of it. It was dirty looking but not the cause. Lift pump pressure is more stable but still very possible to suck it down to ZERO PSI of supply pressure on a WOT run if the grid heater light is off.
I've pull inspected these injector twice now. Still have a rough idle miss either warmed or cold. Blue smoke from one cylinder while idleing but there is no real blow by at all. The cap lays in the hole just fine and doesn't jump out. During the rough idle periods it will jack the rail pressure from 6,xxx roughly to 8,xxx PSI then when is smooths out it drops again.
The lift pump pressure falling to zero at WOT may be trying to tell you something.
I think it is time for a different approach.  I would rig a five gallon container with fuel supply and return.  I would anchor the container in the bed of the truck and go for a test drive and document the results.
- John
This sounds like a rail pressure relief valve sticking open.
I’d recommend taking the drain line off the PRV on the rail and confirm it’s not leaking down. They pop off at a high pressure so if anything is coming out it’s not good.
Also, if your losing prime in the head you can take the return line off the back of the head and measure how much is coming out in a graduated beaker. If it’s too much the mating surfaces on the cross over tube to the injector mating face may be the issue.
  • Thanks 1
 Ok, I'm a novice with common rail. Would the firing of the injectors cause a fluctuation? I would think so, to this extent though I'm not sure.
 Also, what is the preferred pressure from the lift pump?
 This would cause me to question pressure and or volume from the lift pump. Is there a "big line kit" between the lift pump, oem filter and injection pump?
