Shoot the WIF plug with brake clean. Then bag the end and zip tie. Any moisture or oil will cause the light to come on. Typically I always leave the stock filter in place and get the big line kit from @dieselautopower. This way you don't have this issue, manifold coolant heat will warm the fuel up.
Posted (edited)
Currently I have a wif sensor in the airdog water separator. Removed the drain and put the sensor in. I ran a jumper harness from that to the engine harness plug.
Like I mentioned I unplugged it at the harness side and it’s still stays on. I’m not sure if this is a problem from ACS.
I did order a new apps through my work (Inland Kenworth).
Williams Control 131973. I should have it by Tuesday. Hopefully it solves my P0122 issue, I will check the wiring harness I made when I relocated in on Monday to confirm is not melted or something.
Edited by Mace
