The two delo oil's...
O.K Guy's...after reading guesswho's thread where he posted an Oil analysis {see below} It got me concerned and i researched the places i have been buying my oil; WalMart & Advance Auto..both carry only DELO 400LE which in the analysis was rated at the bottom
The DELO400 MULTIGRADE SAE (API CI-4 Plus) was what was ranked at the top along with Valvoline/Cummins preminum Blue.
I have checked on the website's of Advance Auto, SAM'S Club, Autozone,CarQuest,etc.. None of the carry the DELO400 MULTIGRADE SAE (API CI-4 Plus)
Has anybody else checked this out????:shrug:
Richie
9.98 1 Cummins/Valvoline Premium Blue 15W40 CI-4 plus CI-4 plus
17.36 8 Shell Rotella T Synthetic 5W40 CI-4 plus CI-4 plus
21.89 12 Cummins/Valvoline Premium Blue Syn. 5W40 CI-4 plus CI-4 plus
9.98 13 Pennzoil Long Life 15W40 CI-4 plus CI-4 plus
10.88 14 Chevron Delo 400 15W40 CI-4 plus CI-4 plus
35.00 20 Red Line Diesel Synthetic 15W40 CI-4 plus CI-4
Good
10.36 2 NAPA Universal Fleet Plus 15W40 CI-4 CI-4
25.70 10 Amsoil 5W40 CI-4 CI-4 plus
13.51 15 Caterpillar DEO 15W40 CI-4 CI-4 plus
12.68 16 John Deere Plus-50 15W40 CI-4 CI-4
19.99 18 Lucas 15/40 Magnum 15W40 CI-4 CI-4
Satisfactory
9.68 3 Mobil Delvac 1300 Super 15W40 CI-4 plus CI-4 plus
7.68 5 Wal Mart Super Tech Universal 15W40 CI-4 CI-4
9.52 6 Castrol GTX Diesel 15W40 CI-4 CI-4
9.52 7 Motorcraft Super Duty 15W40 CI-4 plus CI-4 plus
9.99 19 Pilot Premium HD 15W40 CI-4 CI-4
12.00 21 LiquiMoly Diesel Special 15W40 CI-4 CF-4
Ho-Hum (least favorite)
10.96 4 Shell Rotella T Triple Protection 15W40 CJ-4 CJ-4
27.55 9 Amsoil Premium Synthetic 5W40 CJ-4 CJ-4
10.80 11 Castrol Tection 15W40 CJ-4 CJ-4
12.99 17 Chevron Delo 400 LE 15W40 CJ-4 CJ-4
TECHNICAL TOPICS . . . . Continued
Satisfactory
HOW ABOUT MY 6.7-LITER ENGINE….
If you have a 6.7-liter ’07.5 Turbo Diesel truck it is recommended
that you use a CJ-4 lube oil. Why? Again, issue 54’s article has the
reason behind CJ-4 oils.
“The EPA tightened their exhaust emissions thumbscrew on diesel
engines starting January 1, 2007, to reduce particulate matter
(PM) and oxides of Nitrogen (NOx) emissions. To meet these
requirements most diesel engine manufacturers are resorting to
the use of diesel particulate fi lters (DPFs). A DPF differs from the
catalytic converters we have used for years on gasoline engines in
that a DPF actually fi lters the entire diesel exhaust stream.
“On the surface you wouldn’t think this would be a big deal—
Europeans have been using DPFs for years. The difference is that
Europeans don’t accumulate mileage like Americans and they will
tolerate much more frequent service intervals. Our EPA has decreed
that the new DPFs must go 150,000 miles before needing removal
for cleaning. This means the soot collected in the DPF must be
burned off in the exhaust system frequently if trap life is to exceed
150,000 miles without removal and cleaning.
“I don’t have to tell you that diesel exhaust is relatively dirty.
It consists of lots of soot (that’s what turns your oil black) and
unburned residues from both the fuel and the oil. Sulfur in the
fuel can signifi cantly hamper DPF performance. That’s why ultra
low sulfur diesel (ULSD) fuel was introduced in the fall of 2006.
Phosphorus and sulfur in the lube oil can shorten DPF cleaning
intervals considerably. Phosphorus (P) can ‘glaze over’ and plug
the tiny holes in the DPF, making the openings effectively smaller
and quicker to plug. Sulfur can ‘mask’ the DPF, making it temporarily
less effective. Sulfated Ash (SA) in the lube is thought to build up
deposits on the DPF over time. These deposits that originate from
diesel fuel and lube oil then make the DPF effectively smaller and
quicker to plug.”
CI-4 VPB has been gone in my area for 6-8 months. I used to use it but since everything went to CJ-4 I started using the Cat oil becasue its still CI-4. I only have about 1200 miles left before I change oil again and have been debating just going with the VPB. We need to see an updated set of test results with only CJ-4 oils to know which si the lesser evil. The amsoil I run in my 03 is also still CI-4, but its not cheap.:spend:
I see nothing in the info as to how and why they are ranked the way they are. Just looking at the list it is obviously based on value and nothing to do with quality.
That's exactly what I was thinking. Didn't want to point it out though :lol: But yeah there is nothing there and seems to me it was just one guy judging everything by their cover.
