Ok, I thought my vp was shot, now I'm stumped. I posted that I was given an 02 QC which had been sitting for 2 years. When I got it started it ran rough, and smoked like a train (white smoke.). Last night I changed the fuel filter (which was black), and noticed the little "o" ring around the cap was missing. MMMM... So I put the new filter in, along with the new "o" ring. Fired it up, and it quit after 2 seconds or so. It lost prime. After bleeding it, the engine ran like new! When I revved it up, there was a little puff of BLACK smoke, but NO white smoke. So I took it out for a drive. Turning at the corner I got into it, and it lit the tires (buckshots) while getting good and sideways. Good God, the torque is addicting! So apparently it was sucking A LOT of air. Then this morning, with the engine cold (doesn't really get cold here, it was 65), it fired up, but was smoking again. Not near as bad as before though. After 5 minutes when the engine was warm it was like a new truck again, with no smoke. Could it be sucking air while cold, and then sealing itself from expansion after it warms up? Where could it be getting air from? I am getting a scanner today, and will clear the codes to see what comes up. any ideas guys? Thanks in advance.Christopher
  • Replies 7
  • Views 1.9k
Don't understand "sucking air",you saying you think you have an intake leak because of the 'white smoke"?:shrug:
Have you checked for codes using the ignition switch 3 click method? If you have not fuel pressure gauge, I strongly recommend obtaining a manual fuel pressure test gauge and observe the actual fuel pressure the VP-44 is seeing at the schrader valve test port. http://www.vulcanperformance.com/Fuel-Pressure-Tester-with-Schrader-Connection-p/fpt.htm
Yeah, I checked the codes before I changed the filter. That is why I need to get a scanner to clear them, so I can get fresh readings. The engine light did go off though! I have to get a fuel pressure gauge, but I am going to get a fass LP to try to keep the IP alive as long as possible. Ill update codes and such ASAP.
White smoke can be coolant as well. Can you smell the smoke? The smell will tell you what it is. If it is sweet it is coolant.
no, it is definitely fuel. the breeze was blowing it into the cab! i had to roll up the windows.
