01 pushrod cover gasket to white smoke
- Replies 16
- Views 7.2k
Wild and Free 4 posts
flagmanruss 3 posts
thowers 3 posts
cajflynn 2 posts
Hello! I need some help. I had a bad oil leak on my 2001 Dodge Ram 3500. I've changed the pushrod cover gasket and put everything back as it was. After that, as I was little to lazy to start it proper way with bleeding injector lines ... I just used ether. Vehicle started and I thought, it was ok ... and it is while it's idling. Problem starts when press the gas. Huge white smoke is comming out of the pipe. Seams to me, like it smells like a diesel ... so all I can think of ... timing got screwed up. Anybody has any idea how to set the timing in VP44? I just put back everything as it was ... but there was no smoke before the procedure.Thanks
