Engine Oil Weight and other Characteristics
- Replies 12
- Views 4.6k
dripley 3 posts
CSM 3 posts
ISX 2 posts
Mopar1973Man 1 post
This isn't an oil comparison debate.. I'll get that squared away right now
I want to explore the different aspects of engine oil and how they effect the engine. I don't understand a lot of things about this, hardly grasp the weight thing. They say heavier weight oil protects the engine more, yet then they say thinner oil gets in places the heavier weight can't because of the smaller molecules. So I plan on ending all doubt in this thread.
Here's some stuff from my diesel book.
To start off, oil has 4 main functions in the engine:
[*]Lubrication: To minimize friction and act as a medium to support the hydrodynamic suspension of the crankshaft and camshaft.
[*]Sealant: Enables the rings to seal compression and combustion gases from the crankcase.
[*]Coolant: Heat generated by combustion and friction must be dissipated to atmosphere with heat exchangers (oil cooler).
[*]Cleaning agent: Condensed by-products of combustion hases end up in the engine crankcase and can combine to form harmful liquids (acids) and particulates (sludge).
Hydrodynamic suspension is what they call floating of engine components due to the film of oil between them. As in, the crankshaft does not sit on the bearing, it sits on a film of oil that is constantly being renewed thanks to the oil pump. The thickness of this film depends on the oil pressure and oil leakage rate back into the oil pan.
Now it's getting interesting.
The viscosity rating of an oil usually describes its resistance to flow. High viscosity oils have molecules with greater cohesion ability. However, properly defined, viscosity denotes resistance to shear. When two moving components are separated by engine oil, the lamina (portion of oil film closest to each metal surface) on each moving component should have the least fluid velocity while the fluid in the center has the greatest fluid velocity. Shear occurs when the lamina fluid velocity is such that it is no longer capable of adhering to the surface of the moving components. When we use the term friction bearings to describe crankshaft main bearings, the friction being referred to is the fluid friction of the lube hydrodynamics in supporting the crankshaft.
Two oils with identical viscosity grades can possess different lubricity. The lubricity of an oil properly describes its flow characteristics. Lubricity is also affected by temperature: Hotter oils flow more readily, colder oils less readily. In comparing two engine oils, the one that has the lowest frictional resistance to flow can be said to possess the greater lubricity. In thick film fluid lubrication, flow friction is determined by the fluid's viscosity, that is, its resistance to shear. In thin film or boundary lubrication, flow friction is determined by the lubricity of the fluid.
Still have no idea why a subzero engine would use 0W and a hot engine uses heavier weight. It said the one with the lowest frictional resistance to flow has more lubricity, so why not run 0W all the time? When I read this I saw a lot of conflicting info..
