Will not start sometimes... Lack of power sometimes...
I have 2001 Dodge Ram with cummings engine. Has the following symptoms
[*]Sometimes you get in and turn key and it will turn over and over and never hits a lick, but if you turn key off and try again it cranks right up.
[*]Sometimes you get in and it cranks the first try
[*]Does not matter if it's hot or cold
[*]Sometimes it seems to be slugish (as in it will slow down on a hill and if you step on it, keeps slowing down), the next drive is just fine all the power you need.
I have done the following
[*]New fuel filter
[*]Checked pressure and it's 21 PSI at idle, using the test location at the injector pump
[*]Not sure about the following, it only pumps when cranking, should it pre-pump when you turn the key on? or does the pump only run when starting?
[*]Soon as you turn key off, pressure QUICKLY (2-3 seconds) drops to 0, should it not hold pressure for a while after it has pumped up?
Any suggestions?
I assumed there was no codes for no check engine light has ever shown, but I was wrong. There is a code P0216.I will need to get a differnt test gauge and install to see what it's doing when it decides to mess up, the one I have is way to short.
Just because you idle pressure is fine doesn't mean your WOT pressure is good too... From another member of the site... :stuned:
http-~~-//www.youtube.com/watch?v=NB8o24rw1eU
So when testing fuel pressure you need 2 number idle and WOT pressure. Because as you just seen you can have a great 19 PSI and at WOT fall to ZERO and be ruining a VP44 in very little time... :rolleyes:
