Trans Hunting?
Ok my trans will skip 2nd when your light on the throttle and go straight to 3rd and when you start easing into it it will down shift to second then go thru the gears just fine. Is this what they call hunting?It's not just doing it one or two times a day it will do it almost everytime, except if you are heavy on the throttle.
  • Replies 16
  • Views 4.6k
I carry the GM gov pressure solenoid conversion which helps with a lot of shifting problems. Do you have a manual lock up switch?
From all I read the best way to fix this issue on a 3rd gen is to install the DTT trans controller. Read nothing but great things about it.
No I do not. It's all stock 40k on mileage
The solenoid is for the 1-2 shift. The dtt unit is for the 2-3. I also got the billet accumulator, and a couple other little billet bits with mine. I installed a dtt shift kit as well when I fixed my hunting problem.
Goerend says they don't like the dtt unit. They use a different one. I think they said they had some quality control issues with them. They are now selling something from tst I think. I went with the DTT unit though because goerend had yet to use any of the new ones themselves and I don't want to be the test guy.
Thank ya, I know nothing about these auto's. I need to figure out what I need to do here so please anyone with knowledge on the subject please donate info.
I don't recall hearing about this issue on other forums.. Seem's odd, how low are the rpms when it shifts, must be just above idle.
I thought the same thing when it started happening to me. Then I searched for it and found it was a very common problem.
Interesting, I always read about the 1-2 shuttle shift.
I will doble check but I belive it is right about 1000.
JL...Check and see if your has the T.V. cable set up like the 2nd GEN'S...Iif so try adjusting the cable....i have had simuliar issues with mine and that fixed it.. was just out of adjustment:shrug:
Richie
I have heard that and it never dawned on me :duh: I will check. I just figured it was changed when they made it a 48r.
I don't think there are any cables on an 05, other than gear select.
On vehicles equipped with a Cummins diesel engine,
the transmission throttle valve cable has been replace
by the transmission throttle valve actuator (TTVA). The
TTVA consists of an electric DC motor, two potentiometers,
and a gear drive system. The TTVA is mechanically
connected to the transmission throttle valve in
the valve body by the “D” shaped opening in the bottom
of the TTVA shaft. Changes in the TTVA position
are therefore transferred to the throttle valve and
cause changes in the transmission throttle pressure.
ADJUSTMENT
The Transmission Throttle Valve Actuator (TTVA) does not require any mechanical adjustments. All changes in throttle
valve position are controlled by the Engine Control Module (ECM).
The TTVA does require an initialization period after the actuator has been removed or replaced. After the actuator
has been removed or replaced, move the iginition to the ON position for thirty (30) seconds. This will allow the ECM
sufficient time to perform the internal calibration procedures to learn the TTVA’s current “zero” position. Once this is
done, check the ECM for diagnostic trouble codes (DTCs). If no DTCs are set relating to the TTVA, the TTVA is fully
calibrated and ready for use.
I knew the cable would be to easy. It is still under warranty so I guess I will try. I know what they will say though, we could not find anything. If you put your foot in it it will shift just fine but when you just have thr throttle cracked it will skip 2nd and go straight to third give it a little more throttle and it will down shift to 2nd then up shift right on through the gears.:shrug:
The problem can be fixed by changing the shift points. Goerend has process for moving a gear in the ttva. Or you can use the dtt shift enhancer.
So what is the best direction to go the gm solinoid, trans controller or what I need to fix mine and about 3 other people I know with the same problem:thumb1:
The gm solenoid is an upgrade for the 47re or 48re. People are not using the gm brand solenoid now though. They are using the Borg Warner version because it is cheaper. Same thing otherwise. It will definitely help the 1-2 shift.
