Intake question, sucking air in somewhere?
Do the bolts that hold the rear engine lifting bracket on the head go through the intake housing and do they need thread sealer on them?Reason I ask is I just installed the scheid 100 hp injectors and was test driving and looking for leaks and when I spray things down with brake cleaner It is pulling it into the intake when I spray around the # 5-6 injector line/lifting bracket area.Intake cover and manifold area are ok but it is the area behind it that causes it to start sputtering when I hit it with brake cleaner, only thing I could think is if it was following the lifting braket bolts into the intake?Any ideas?
