For Sale - 2006 Dodge Ram 2500- Flatbed for long box bed Winch bumper Flat Bed for Long Box 3rd generation Cummins Tootlbox are included with key I have a flatbed for 3rd Generation dodge Cummins. This flatbed comes with a gooseneck hitch already in the bed. The winch bumper is part of the set. Tootlbox have a key to lock and unlock all box a single key. There is rust starting and electrical will have to be sorted out on your own.
Price: $1,000.00
I 'thought' I had started a thread on Cab Lights before, but the search turned up nada..
At any rate, I installed clear lens/amber LED cab lights this past weekend. My truck did not have them from the factory, so I bought some EuroLite 9-LED ones for a Ford, from eBay for $70 delivered. I liked the Ford-style ones better, so that's what I went with. They arrived in a box, no instructions, no packaging, only an invoice, lights, and packing peanuts...
Since my truck didn't have cab lights, I had to drill..
In a nutshell:
[*]Drop headliner (phillips screws hold visors, pinch clips for overhead console, T20 for pass. side grab-handle, T20 for QC latch trim covers, snaps for a-pillar trim
[*]Tape a straight line from top corners of windshield.
[*]Measured 6" up on each side, and taped another straight line across.
[*]Found Center line, marked it on the tape
[*]From center line, outward, measure 8.5", mark it
[*]From the center line, outward, measure 21". mark it
[*]Once you have these lines marked, measure 5.75" from top edge of windshield, back. This mark will be the forward-most point of the cab light. (this will put the wiring of the Ford-style lights right about over the inner cab-wall hole.
[*]Using the base of one light, make a cardboard template of the light base, and drill holes where wiring and screw holes will be.
[*]Mark center line on template. This will aid you in lining/centering/straightening up the lights and marking the drill locations.
[*]Align center line of template onto each parallel line for the light locations, taking into account the front of the light base on the 5.75" back-set mark.
[*]Drill the three holes required by the lights (2 mounting screws, one wiring hole)
[*]I used an 1/8" (.125) bit for making the #8 screw pilot holes. Also a pilot hole for the wiring, to be drilled out to 3/8", or .375
[*]Apply a dab of clear silicon on each mounting screw hole on the cab, and a blob around the wiring at the light base
[*]Place the light base onto the cab, carefully ensuring that it's aligned properly.
[*]Mount the light bases using (purchased separately) #8 x .75 SS sheet metal screws, and snug them down evenly
[*]Once all are mounted, move inside the truck and wire lights in series.
[*]I grounded them within headliner, and ran 'hot wire' down driver's a-pillar, to headlight switch (remove bezel, 3 phillips screws and slide headlight switch out. Wire is black/yellow.
[*]Check for proper operation.
[*]Reinstall everything if all is good to go!
Pictures to follow.. I didn't take many, but I've got a couple I could add.
