Dang it...put the pressure on him...the sale on the ats is only good thru tomorrow. I'm joking about putting pressure on him....well, maybe not
hahaha yeah common dually - help a brother out :) in mean time speak with thracing as well - those guys to some heavy modifications and performance work at their shop ;) He might hook you up - haha
You put the turbo gasket on the exhaust manifold run some bolts in,then look at the inside of it. There will be material under the gasket on the manifold that can be ground off.
The turbo example has the wrong gasket on just look at the edge. It was the only one i had. You also do the other end with the gasket. You can see the extra meat pointed out with the bic pen.
You can take an awl and scratch a grind line. Then grind on a angle to get up to the gasket. Once you get up to the line work the inside part. You have to know when to stop so you dont end up with a boat anchor
the little things can add quickly. it applies to every thing we do. we discuss this at work quite often. 27 supers aving a $100 a week for a year = $140,400 a year. works the same with our trucks. of course with that kinda of money i could just buy that pretty ss header.:lmao2:
