- Replies 13
- Views 2.1k
02cumminsdude 5 posts
KATOOM 3 posts
dripley 2 posts
anoldbiker 1 post
Hey guys, this is kind of a spin-off from my last no-start thread regarding my fuel pumps. But I had totally forgotten about another issue I had while flushing the cooling system. I had my truck idling for about 20 minutes before it shutdown, and the entire time, the all the hoses got very hot except the upper radiator hose, and coolant was not cycling through everywhere while I had the cap off, just kind of started to sizzle. So I put the cap on, and pressure still did not build and the upper hose remained cool. Is this probably a waterpump? If so, I would like to replace it while I'm doing my pumps. However a scarier issue I read, was possibly the front of the crank being broken? To make it worse, I noticed the night before the truck shutoff that the damper was a little wobbly, therefore, I bought a Fluidampr with my pumps. Should I pull the valve cover and rotate the motor with a wrench and watch for all the valves to move? You guys helped me out a lot so far, being new to my diesel, so hopefully I can get some good news on that at least. Thanks
