oil consumption/usage
- Replies 59
- Views 12.6k
al_fol 24 posts
dorkweed 9 posts
flagmanruss 5 posts
mrtowman4u 5 posts
Could someone please tell me where my oil is going?? Last oil change was about 4k ago with Valvoline Blue and a Wix gold Filter. Checked oil this morning after truck had sat overnight on level ground. Pulled the stick and nothing, did it again, same result. Truck does not leak, has good oil pressure, anti-freeze looks good, no oil underneath, it does have a little blow-by and there is 147k miles on motor. I do have a oily residue on my exhaust tip that does not easily remove with soap and water. I run a 200:1 ratio of 2 stroke oil(TCW3) in my fuel, not sure if that could cause the residue. Could the turbo be blowing the oil out? Any ideas from the great minds?? Please guide me.
