- Replies 14
- Views 12.2k
Mopar1973Man 5 posts
Rogan 5 posts
dorkweed 2 posts
98whitelightnin 1 post
Ok, so yesterday (of all days), I get in the truck after work. Fire it up, glance at the Attitude monitor, see oil pressure readings, and roll out of the parking lot. I get about 500yds down the road when I glance to the monitor to see the screen completely pixeled.. IOW, every LCD pixel was on; the screen was solid black.I pulled over, cycled the ignition, but this time nothing... at all.. only the back illumination and buttons lit up. the screen completely blank. I shut the truck back off, unplugged/replugged the control box, and checked the green connector for the monitor.Still same thing.. illumination and blank screen.I tried touching the power-level arrows on the way home, and it works as normal, you just can't see anything. Got home, shut the truck off, and the turbo timer worked fine. Tapped the brake pedal and got out. An hour or two later, I went out and turned the key on to check the J/A screen.. still blank.This morning, I get in the truck to go to work, BOOM! screen works now.. Well, it did for about 30-45 seconds, then went back to full pixelation..I'm at a loss.
