- Replies 20
- Views 8.4k
								Mopar1973Man 6 posts
								CUMMINSDIESELPWR 3 posts
								diesel4life 3 posts
								rancherman 2 posts
I Bought a reman vp44 pump combo set with the lift pump and fuel filter from Thoroughbred Diesel and I am only getting 12 psi pressure at the fuel filter out of the new carter lift pump. The truck runs good till you start driving under a load the pressure drops down to 7or8psi and it throws the 1689 no communication between the ecm and injection pump. Did I just waste money buying the combo with this carter lift pump? Has anyone else dealt with Thouroughbred before?
