Occasional Dead Pedal
- Replies 6
- Views 1.7k
Mopar1973Man 1 post
dripley 1 post
Texas CTD 1 post
scummins 1 post
Hi all,I'm having this problem with a 99, 5 speed, fairly stock, ~25,000 miles on new injector pump , little bullydog 'chip' and BHAF. I'll be going down the road normal, and suddenly I'll loose all power, it just wants to idle. Now if I hit the clutch, and let the fuel pedal all the way out, then push it all the way back in, and let it all the way out again, it's fixed, and I have power again. and when it has this problem the check engine light turns on and stay on for about 30 minutes. I understand checking for codes would be very helpful, a friend of a friend may have a code checker I can use but I'm not sure. Is there something I can do with the key to check for codes?thank you for the help.
