I'm planning on getting a quad adrenaline with pulse as soon as my bank account allows and I'm wondering if the high idle works good. Or should I be doing a manual setup like I found on this forum?
You will like the Quadzilla Adrenaline w/ Pulse, I don't think we have ever had a complaint about it. (unless it was from the guy in a stock truck trying to keep up :cry2:) Let me know if we can help. Thanks, Kenny 352-636-0812
Posted (edited)
Remember you don't get the 3 cylinder high idle with the quadzilla... this where the serious heat is created and will warm up a engine rapidly on a super cold day. Where high idle itself does help but doesn't create enough virtual loading to create heat... Here is a simple temp I clipped from the High idle page to show the differeences... This is cold start with approximately 25*F-30*F outside temperature and the loading was measure with a ScanGauge II.
Yes but you cant turn it on or adjust it without the pulse. p.s. love the adrenaline!!! but the pulse leaves a lot to be desired!Just got mine back after a month at quad because the screen wouldn't display numbers in temps under 55%. after 40 bucks and a new screen it works better but still not perfect.
Hey, Then it doesn't work without the Pulse!!!:sad4: Oh well I like my Edge Comp!!!!!:razz: Later, Winslow
Just to verify you can't have 3 cylinder high idle with the pulse correct? :confused:
That was my point lol!
I haven't had an issue with that like some people. I have the flash from the smarty for the 3 cyl high idle,and I have the adrenaline set at 2 minutes for the high idle to come on. It works like this for me, cold enough temps for 3 cyl high idle to come on, it does and thats it. If not cold enough then just the adrenaline goes to high idle. Never had an issue.
I was at a diesel shop today and the guy said he'd had customers get dodge to de-activate their high idle because of the 3 cylinder part. Talked about concerns of cylinders running dry etc. Is this a valid concern? Seems to me dodge wouldn't put it in there if it was a problem. I hope it's ok cuz i love the sound of it!
Hey, I've never heard of a problem with the 3 cylinder high idle!! It was installed my Cummins, but Dodge opted not to use it!!:wink: I don't see how they would run dry?????:confused: Later, Winslow
