Inside VP44?
I am in the middle of changing another VP I have done so many of these I keep one in stock on the shelf in my shop, but i have 8 of these trucks to keep going. Anyway I have been trying to figure more out about this pump, at least why they fail, more to the point why mine fail. I normally take them off send them away and thats it. I know it is either the electronics or the mechanical part. My question is has anyone went in a dead pump to see.
  • Replies 14
  • Views 3.2k
One question that begs to be asked is do you have fuel pressure gauges in the trucks and what pressures are you seeing?
Most of these trucks are drove by people that work for us so I havent invested much money in after market products, that being said yes they all have gauges weather the drivers ever look at them idk least they tell me they do when i asked the driver this question he told me 15 or 16.
Next thing that I read about is using two stroke oil in the fuel, but I can imagine that would be a royal PITA for your drivers............. Some pumps have mechanical issues and some have electrical issues. Maybe someone that knows more about the VP pumps will chime in. I know the P7100 trucks a bit better.......
There is a few things that go bad, but there are very expensive machines that test them to make sure they are working right. That's why they always charge a huge core.
I have a junk VP all packaged up ready to send to Mike, it's been sitting in the garage for the better part of a month now, I will get it out soon I PROMISE!!!. I was going to dissect it just to see what they're made of, but thought it would benefit everyone more if someone did it and documented it. I think Mike would be much better at that end of it than I.JR
I was just wondering if anyone knew what to look for inside to determine the cause of failure. Im not in any danger of damaging the pumps ability to be used for a core? Thanks Mopar1973Man saw the sticky not sure where you found that but good work!!!!
I'm not sure if they would accept a core knowing that you were inside it. They are very finicky about cores. The one that I have was given to me by a guy that tried to change the pump without knowing what he was doing. He tried to pry the gear off the front and chewed up the nose of the pump in the process and they rejected the pump as a core. JR
If a pump has signs of being opened the pump core is denied. So if you send me a pump you not going to be able to use for a core.
:thumbup: JR
Has there ever been feedback from an actual pump service facility or technician regarding common failure points on these pumps?
